Power Connections- PCI-E
Solved by KeltonDSMer,
I am having a little trouble following. So there are two pci-e cables, and both have a 6+2 and a 6pin plug? You want to use the two 6+2 plugs which means using both cables, right? Does your 280x require 2x8pins?
If so, this is actually the ideal solution electrically because any time power is used on a "string" of plugs, the wires upstream near the PSU have to carry the current for all the plugs on the string. I see no downside to using the two cables other than having the extra 6pins dangling around, making cable management a bit harder to deal with.
