My question is this at the moment i have an Intel i3 540 @3.07GHz and an EVGA GTX 750 1Gb, i really would like to play DayZ at a comfortable 35 to 40 FPS, would i need to upgrade my CPU or will the i3 do just fine and all i really need to do is adjust the Graphical settings. Thanks!!
https://linustechtips.com/topic/192386-best-cpu-for-dayz/
Specs and budget.
Most beast pc's will barely hit 50fps depending on where they are. It's an early Alpha (scam)
https://linustechtips.com/topic/192386-best-cpu-for-dayz/#findComment-2606333
I'd just adjust the graphical settings.  Day Z runs like shit right now.  A friend of mine doesn't get great frames on a mobile i7 4700HQ so I wouldn't worry about it too much.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/192386-best-cpu-for-dayz/#findComment-2606337
Specs and budget.
Right now im at around 150 and am thinking of getting the i5, but if my i3 can do the job just some setting tweaks than im fine with that.
https://linustechtips.com/topic/192386-best-cpu-for-dayz/#findComment-2606372
