will my build work ?
Go to solution Solved by SAV1OUR,
10000000000000000000000000000000000% sure it will
i am planning om building a pc my self but i'm not 100% sure it will work .
this is the link to the dutch site i will be using  (yes i am dutch)
http://azerty.nl/winkelmandje/winkelmandje/?legen=1&product%5B452185%5D=1&product%5B543061%5D=1&product%5B561034%5D=1&product%5B582391%5D=1&product%5B626550%5D=1&product%5B361602%5D=1&product%5B563659%5D=1
it would be amazing if some one could check if my build would work!
https://linustechtips.com/topic/177515-will-my-build-work/
Specs
https://linustechtips.com/topic/177515-will-my-build-work/#findComment-2382170
That will definitely work...unless hit by lightning ofc  :P. All jokes aside I would recommend getting an SSD as it would make the most noticeable difference in everyday usage. :)
[ Rig: CPU: 4930K, GPU: EVGA 780TI SC x2, RAM: 32GB Corsair Vengeance 1600MHz, Mobo: ASUS P9 X79 LE, Storage: 120GB Samsung EVO + 2TB Seagate Barracuda, PSU: Corsair RM1000 ]
https://linustechtips.com/topic/177515-will-my-build-work/#findComment-2382180
Unless a part is DOA.
you had to be that one guy didn't you...
Specs
https://linustechtips.com/topic/177515-will-my-build-work/#findComment-2382282
