H440 LED cables
Solved by scaryjam823,
So the H440 comes with a 1-pin LED P+, 1-pin LED P-, 2-pin HDD LED, 2-pin POWER SW and a 2-pin RESET SW which comes to a total of 8-pin. My question is am I supposed to plug this to the motherboard or the power supply? Thanks and sorry for the absolutely dumb question.
Those are your front panel headers, they go on the front panel header on the motherboard. You couldn't even plug them in a power supply if you tried unless you modified the connectors, which if you went that far something should have told you it was wrong.
