Hello
I have a little problem with the noise of my All in one CPU cooling solution, the H80i
(if needed, rest of the hardware in my build log: http://linustechtips.com/main/topic/95053-define-mini-hackintosh-dualboot-little-beast-matx/).
The Temps of my CPU are great, around 30 Deg Celsius and with load up to 35-40. But here is my problem: The fans which are connected to the Radiator spin around 2300 rpm, which is really high. The fans are 2 Corsair 120mm High Performance (will buy noctua ones soon) ones and it seems, that I have no option to manage this speed. I also set the profile for CPU Fans to Silent which didn't change anything.
Has anyone faced similar problems, or does anyone knows a solution?
Thx
Leo
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
https://linustechtips.com/topic/169771-h80i-noise/
