Problem with HDD´s
Go to solution Solved by AbydosOne,
4 hours ago, marcoloaded said:
I got a pcie to 8 port sata, 1m meter long sata cables
My bet is on the SATA card being flakey, but the 1m SATA cables probably aren't helping. At absolute minimum, I would recommend switching over to an LSI HBA (9207-8i or 9300-8i) so you can eliminate that as part of the issue. Those cards will also have better quality PHYs to drive a meter of cable (note you'll need to get some SAS to SATA cables too, but those aren't super expensive either).
I recently build an external enclosure for 8 HDD bays and got pcie to 8 port sata, looks like a NAS but is internally connected to the desktop. I got some NAS drives to put on it and sometimes I get the "K:\ is not accessible. A device which does not exist was specified." It happens randomly and I have to use the EaseUS Partition Master to repair it. Does it have to do with me getting NAS drives on desktop? Could it be the pcie to sata card? Could it be too many drives on windows?
The drives are Toshiba N300 4TB, WD RED Plus 4TB and Seagate Ironwolf 4TB. Windows 11, x570 mb
https://linustechtips.com/topic/1629158-problem-with-hdd%C2%B4s/
How are you getting the data from the desktop to the enclosure? SATA? PCIe?
pcie to 8 port sata
This could very well be the problem, depending on what kind of card it is (the cheap ones are horrible).
No.
Also probably no. I've done at least eight drives on Windows before.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
No.
Thank your for the reply. I got cheaper one from amazon. I also got 3 drives internally. I got a pcie to 8 port sata, 1m meter long sata cables and also power extensions to connect to the psu.
Network:
  • 1 month later...
23 hours ago, marcoloaded said:
That worked out! Thank you. Got a LSI 9300-8E
Okay, I definitely read your response yesterday (which wasn't this) and mentally marked it to come back to... how did you fix it?
Network:
