Budget (including currency): $3,500
Country: USA
Games, programs or workloads that it will be used for: Modern AAA, Compatibility with older games, Blender use later down the line
Current List Idea:
https://pcpartpicker.com/list/st4Kfd
Resolution mainly is 1080-1440p and refresh rate minimum 60fps at the highest graphical settings. Current System is an i9-14900k with an RTX 4090 but in a full desktop case. May swap 4090 into this small system because I want to downsize for traveling. I'm well aware it's overkill but I want it to last upwards of 5-10 years before another upgrade.
https://linustechtips.com/topic/1626014-small-form-factor-build-idea/
Country: USA
Current List Idea:
Dawg how much SSD storage does one need.
Also I WOULD NOT recommend amd for blender
A lot.
I am already using 5TB for my games and OS. That's not including my downloads. And I want to make sure I have more than enough for storage for later games as they are only going to get bigger. Better to plan ahead then scramble when I find myself with no storage remaining.
And I am well aware AMD GPU's are not for blender so that's why I am considering throwing my RTX 4090 into this system and put a different GPU into my i9 system.
4 minutes ago, Jojo0607 said:
A lot.
Personally, I don't see how you even get to that much, but if you want 12tb you can have 12tb. I would do this instead imho
PCPartPicker Part List
CPU: AMD Ryzen 9 9950X3D 4.3 GHz 16-Core Processor  ($679.99 @ B&H)
CPU Cooler: Thermalright Aqua Elite ARGB V6 70.84 CFM Liquid CPU Cooler  ($44.90 @ Amazon)
Motherboard: ASRock B850I Lightning WiFi Mini ITX AM5 Motherboard  ($169.99 @ Newegg)
Memory: G.Skill Ripjaws S5 96 GB (2 x 48 GB) DDR5-6400 CL32 Memory  ($339.99 @ Amazon)
Storage: ADATA XPG GAMMIX S70 Blade 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($237.49 @ Amazon)
Storage: Western Digital WD_Black SN850X 8 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($639.99 @ Amazon)
Video Card: Gigabyte WINDFORCE SFF GeForce RTX 5080 16 GB Video Card  ($999.99 @ B&H)
Case: HYTE REVOLT 3 Mini ITX Tower Case  ($130.00)
Power Supply: Lian Li SP850 850 W 80+ Gold Certified Fully Modular SFX Power Supply  ($134.00 @ Newegg Sellers)
Case Fan: ARCTIC P12 Pro PST 77 CFM 120 mm Fans 5-Pack  ($36.99 @ Amazon)
Total: $3413.33
Generated by PCPartPicker 2025-11-03 16:40 EST-0500
Total: $3413.33
ASRock I have been hearing is having issues with AMD X3D Cpus blowing up, Granted 9800x3D but still. My SATA 4TB is for my older lighter games like Borderlands 2 (which with PhysX will not run very well on the 5080 so highest I will go on Nvidia is 4000 series) and it also may get switched around in other systems for different needs.
I chose the fans to replace as I did is for the static pressure. Overkill rpm sure but I don't need to run them very high to get that static pressure. PSU I want to have at least 1000w and platinum
The P12 pro has very good static pressure performance.
I meant to click this ASUS board below for 179 but I did a misclick.
platinum doesn't really matter that much, because you are only drawing like 5 less watts from the wall. Theres the Thermaltake Tough power for 175 that's pretty good if you really want 1kw which you don't really need
7 minutes ago, daygeckoart said:
With that budget you should be gaming in 4K. Trust me, you will notice a huge difference.
Yes I am aware this is more for 4k, but I rather be overkill to run than to not run because of something stupid. Am I stupid for this... Probably.
I chose the Gigabyte board that I did because of more NVMe spaces. Although I did consider that ASUS board with it being a little cheaper, but storage I want to keep open as much as possible. For psu's I was going based off of the tier list from ZTT for SFX as that's the size of PSU this case takes. The Corsair one matches what I want and is one of the highest rated for SFX. I will keep those fans in mind for when I finalize the build.
More that it's a waste to have that much power and be gaming in 1080p or 1440p. Those were the resolutions off monitors in 2004, and monitor tech has stagnated for such a long time. 4K isn't even that high res and should at least be the baseline now in 2025!
I don't think you will need more than 12tb of SSD storage on your second PC for travelling. The toughpower SFX is A- rated which is pretty good enough and I do not think the corsair one warranted the cost increase, considering that hot take, the PSU tier list doesn't matter that much. The ranking doesn't really matter past B+ and is only really useful for deciding between 2 similarly priced power supplies
@GuiltySpark_ It would be a waste to use this PC at 1080p or 1440p
As of right now those are the monitors I already have on hand. I will upgrade them when I have a system that can actually push those kind of monitors. Sure I do technically have that now with the i9-14900k and RTX 4090, but before that I had a i7-990x with a GTX 1080Ti and before that was a Core 2 Quad Q9650 with a GTX 780Ti that I turned into my Windows XP machine.
Whether I got upgraded monitors then, now, or later, I will still be wasting something.
I mean yeah. But an expereince on those upgraded monitors and getting a worse PC would still be better then getting a better PC and keeping your old monitors
I guess so. Even then all my systems are built to be in one place. I am changing this to better align with my needs. That's why if I need to upgrade my monitor, I can use any remaining money from my budget to put to a monitor that can be taken on the go cause in the end I would still need a monitor as non of my current ones are portable. My only portable one is an Artist Pro 10 from X-Pen that is 1080p 60hz that I don't really use as I now have a foldable laptop dedicated to drawing which replaced my old laptop that I had using that as secondary display for such tasks.
