GPU not pulling full power when full usage.
Solved by FilipposTechGR,
4 minutes ago, joe_ollie909 said:
Yes, that can be normal. GPU utilization % just means the card is busy, but the actual power draw depends on the workload. Some games like Squad are not very power-hungry and don’t push the GPU to its max TDP, so you’ll see high usage but relatively low watts.
If temps are fine and yours are, there’s nothing wrong. Power draw will vary a lot depending on the game/engine, resolution, and settings. In heavier titles you’ll likely see much higher wattage closer to the card’s rated limit.
