Help With New Rig
Go to solution Solved by Dr. Will0hlep,
20 minutes ago, Aradi said:
Is This Build Good ?
Budget (including currency): 1100 BHD
Country: Kingdom of Bahrain
Games, programs or workloads that it will be used for: GTA V, God Of War Ragnarok, Factorio , WWE 2k25, kingdom come deliverance 2 , crusader kings 3 , Blender.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Making an AMD Build
I have a SAMSUNG Odyssey G5 Series 27-Inch WQHD and I don't need to buy any peripherals . I Want to purchase as soon as possible. (The CPU will be from a different store and boxed not Tray).
I'm not sure wither to buy the Gigabyte AORUS Radeon RX 9070 XT Or GIGABYTE Radeon RX 9070 XT Gaming OC.
I think we can do a bit better here on the balance of budget front and get you better performance.
I think you could go for a 2x16GB 6000Mhz CL30 memory kit, a B series motherboard, and a 9800X3D, and then with the savings upgrade the 9070XT to a 5080.
Given the stated use case, I'd doubt the downgrade to the ram will effect you. As for the motherboard downgrade, that will only matter if there is some feature on only X series motherboards that you really need (motherboards don't really effect performance).
The downgrade to the CPU may have a negative impact, but it should be smaller than the positive impact of having a 5080 instead of a 9070XT.
 For The CPU Store
For Everything Else Store
https://linustechtips.com/topic/1615184-help-with-new-rig/
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1615184-help-with-new-rig/#findComment-16749256
 For The CPU Store
The only thing I would change is the video card due to Blender. Look at a RTX 5070 Ti.
https://linustechtips.com/topic/1615184-help-with-new-rig/#findComment-16749260
