Gpu help, wait or buy?
7 minutes ago, Muttles said:Budget (including currency): 750$ cad
Country: Canada, Ontario
Games, programs or workloads that it will be used for: work, apex, sm2, wow, bg3
i7 13700kf
32 gigs ram ddr5
1tb Samsung 990 pro SSD
Nvidia 2070 8 gig
Corsair RMx shift RM850x
Fractal North
Dell 40 inch ultrasharp u4025qw screen with thunderbolt
Hey guys I upgraded my PC in late 2023 but decided to skip the GPU upgrade. I have limited cash to spend on a gpu now (750 cad ish) and I'm not sure if I should upgrade or wait a few months and try to grab a 9070 XT. The 7800 xts seem to have dropped in price.
I really dont know if I should upgrade but my 40 inch 4k screen makes the 2070 feel slow and older.
So what should I buy?
The 7800 XT is twice as fast as the 2070 so you will be getting quite the performance uplift.
You also have a strong CPU to back it up so you will get full usage out of the GPU
I would say that the 7800 XT is a fantastic purchase.
here is a 15 game average at 4k by Hardware Unboxed
That being said, the 9070 XT is significantly faster than the 7800 XT at 4k resolution.
It really depends on the price you are comfortable with spending and if you want to wait.
