I'm trying to find a sub-4L itx case which doesnt have space for a PSU and instead relies on you using picopsu or similar.
But it needs to have a half height single (or dual) pci-e expansion for gpu.
So far i've found https://www.amazon.com/dp/B07GZGXW6K but I would have to cut an opening for the pci-e, and I'm really not a big fan of it's design. However I do like the full glass top.
any suggestions?
specs are:
asrock IMB-A8000M
nvidia rtx a2000 custom single slot half height gpu
Picopsu M3-ATX (just used as a reliable 12v source)
https://linustechtips.com/topic/1604739-psu-less-itx-case/
I think this is what you are looking for: the A09m https://www.aliexpress.com/item/3256806426866284.html
In pursuit of knowledge and mistakes.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home BOINC
https://linustechtips.com/topic/1604739-psu-less-itx-case/#findComment-16678834
Be careful! AliExpress isn't known for its legitimacy for PC parts! Though this does not look like a scam... 😁
https://linustechtips.com/topic/1604739-psu-less-itx-case/#findComment-16678841
yes that is.
its not perfect, two pci-e slots instead of one is less ideal for my setup, and the design looks mid, but it is the best option so far.
https://linustechtips.com/topic/1604739-psu-less-itx-case/#findComment-16678901
