So, I have a Sapphire pulse 7900 XTX, but I’m having an issue. When I try to have both HDMI ports plugged in, one to my monitor and one to my TV, I get no display on either panel, if I run one HDMI port and one DisplayPort then I get a display on both panels. I have tested each port individually and they all work, I just can’t run two HDMI at the same time, any thoughts?
All latest drivers installed
All latest updates
windows 11
9800x3D
32gb DDR5
Asrock X870E Taichi
Samsung 990 Pro
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/
All latest updates
windows 11
9800x3D
32gb DDR5
Asrock X870E Taichi
Samsung 990 Pro
Still something to be sorted in the future as you may need both HDMIs, but...is it an issue to run the 2 different ports? If you get a display with one DP and one HDMI then issue, temporarily at least, solved?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16654846
All latest updates
windows 11
9800x3D
32gb DDR5
Asrock X870E Taichi
Samsung 990 Pro
As above, but don't you use DP to your monitor anyway?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16654869
They might have an older monitor that has HDMI but no DP.
But even in this situation, a DP-HDMI adapter might be the easiest, arguably cheapest, fix.
I've gotten to know some stuff, but am far from omniscient, so don't take my advice as gospel and wait for other opinions - I just like throwing in my two cents when I can.
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16654958
You comfortable with that assumption, given...
9800x3D
32gb DDR5
Asrock X870E Taichi
Samsung 990 Pro
7900XTX
I would assume he has a monitor younger than 10 years old with a DP port that should be used, negating his issue entirely.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16655035
Yes I definitely could, it’s just me wanting things to work as intended and to have all ports function properly.
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16655203
Oh I'm very much aware it was unlikely 😅
But I have coworkers who have borrowed old monitors from the office (the kind that still have a DVI/VGA port alongside the HDMI) until they were able to afford a better one with modern connectivity after their rig upgrade. So it was not out of the realm of possibilities he upgraded the rest of the rig beforehand too.
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16655309
DP is the standard for monitor-PC connections usually. HDMI is often just an additional if you dont have any DP ports or want to hook something else up like say, a firestick to a monitor. But some monitors wont even run at their full refresh rate without DP
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1601532-7900-xtx-port-issue/#findComment-16657235
