Budget : 400$
Country: USA
Games,that it will be used for: i would like to game on it, games like Fortnite, cod , forza 5 , csgo2, rainbow 6, f1 24, gta 6 when it comes out.
Other details am planning on buying by march id like to game on 1080p 120 hz monitor, i would prefer the build to be pure performance.
If absolutely needed i could add 50$ to the budget.thx
https://linustechtips.com/topic/1598276-budget-build-help/
9 minutes ago, Fredy_25 said:
Budget : 400$
Country: USA
You are asking a lot for a very low budget.
https://pcpartpicker.com/list/cBzJYN
No case. Cant afford.
Its over your max 450 budget and you can get a cheaper GTX 1650/super but the RX6600 is a lot faster.
The used market is your best friend at this price point however.
But you gotta do some Scrapyard Wars stuff.
Please dont cheap out on a PSU.
https://linustechtips.com/topic/1598276-budget-build-help/#findComment-16636597
19 minutes ago, KodokuJ said:
Are you willing to buy used?
And sorry to say, but we can't really judge how GTA 6 will be because that has yet to release on console and I expect it'll be a couple years til it's on PC.
By CoD are you just saying like the newest one?
Yes i am willing to buy new I just dont know which components to look for, cod warzone
https://linustechtips.com/topic/1598276-budget-build-help/#findComment-16636613
