Msi Project Zero Build Help
Go to solution Solved by Sant_HH,
2 hours ago, KFC263 said:
The cable in the photo is a part of the fan hub that came with the case, I’m quite sure it’s supposed to go in the jargb_v2 port (jrainbow), but it doesn’t properly sit in there and falls out with the slightest touch.
JARGB_V2 is the correct header to plug it into. It should go in without any problem.
The motherboard has 2 CPU power ports, am I supposed to plug both of those in to the PSU?
Yes, you need to plug both in.
And lastly most of the cables are going to get quite bent if I put the back of the case on.
As long as everything is plugged in properly should be fine.
I have a few questions about building my pc.
it is an msi m100r pz case, and project zero motherboard.
Partlist: https://au.pcpartpicker.com/list/CWDPJn
Sorry if this isn’t formatted well, I’m on my phone.
Thank you in advance.
https://linustechtips.com/topic/1595679-msi-project-zero-build-help/
In pursuit of knowledge and mistakes.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home BOINC
IT’S IN ALL IS GOOD
Thank you so much for the help, yet the jargb only goes in halfway and just falls out with ease.
Edited by KFC263
