Hi everyone I've just installed my new cpu ryzen 5 5600x and the idle temps don't look to great compared to others I've read online. Am I doing something wrong. Installing the cooler is not difficult it's only two screws, I turned each screw 3 times going from one to the other evenly so don't see how it could be that. Am I applying enough or to much thermal paste used the spread method. Another wierd thing is my fans don't seem to speed up in icue the sensors say they are but it used to sound like a jet engine when put on max now it doesn't seem like they make a whisper still all spinning and can control the rgb using a thermalrite assassin king 120 SE air cooler.IMG_1095.thumb.jpeg.e4448075d48e37b32038f0be6f06bfb3.jpeg
https://linustechtips.com/topic/1591669-what-am-i-doing-wrong/
That's plenty of paste.
Also, the idle temp is completely irrelevant, what matters is the load temps. As long as your CPU isn't overheating under load, it's completely fine.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1591669-what-am-i-doing-wrong/#findComment-16591802
That's normal AM4 idle temps, check full load temps to be sure the coller is properly installed
https://linustechtips.com/topic/1591669-what-am-i-doing-wrong/#findComment-16591803
OK thanks for the reply what would be the best method to test under load I have hwmonitor can I just run some games and use that
https://linustechtips.com/topic/1591669-what-am-i-doing-wrong/#findComment-16591812
Sure
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1591669-what-am-i-doing-wrong/#findComment-16591815
8 minutes ago, W3e2e1 said:
I'm running the benchmark thing in cyberpunk and it's not going over 60 with msi afterburner on screen monitoring
That's pretty good
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1591669-what-am-i-doing-wrong/#findComment-16591829
