So hi, um I have already ordered an order for my computer which is a wifi card. which its a no name brand but its only show ANATEL. This wifi card is very cheap but seems to be useful. I talked to the seller, does this support windows 10? and he said "yes". so I just ordered it and installed it when it arrived. when I turn on my computer I am greeted with a blue screen of death.
https://linustechtips.com/topic/1590312-please-help-with-this-networking-thing/
Most likely that (11 years old!) WLAN card is just dead, causing your computer to be unstable and windows to crash.
General tip, don't write your text into a single, overly long line, that makes it really annoying to read.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
aw.... i just bought it today i thought it would work for any windows..
It should, but it's evidently broken on a hardware level.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
should i buy new one ?
If wired internet via an ethernet cable isn't an option for you, there's kinda no other way. Though I'd recommend you to buy a new card which will then also have support for newer and more secure WLAN standards.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
which one should i get ? tp link looks good.
TP-Link generally makes good stuff, so it should work fairly well.
In general, wired ethernet has lower latency (and is built into virtually any modern motherboard), so if you can, use that.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
