GPU running hot after boot
Go to solution Solved by Bamise,
Here’s the reformatted version with the conclusion at the top:
Conclusion
A crypto-miner Trojan infected me (Trojan.Crypt) and managed to remove it using the free version of Malwarebytes. Below is the detailed scan report:
Malwarebytes Threat Scan Report
Website: www.malwarebytes.com
Log Details
  • Scan Date: 1/15/2025
  • Scan Time: 9:52 PM
  • Log File: 99d7cf54-d382-11ef-835d-00e04cc1162b.json
Software Information
  • Version: 5.2.4.157
  • Components Version: 1.0.5116
  • Update Package Version: 1.0.94536
  • License: Free
System Information
  • OS: Windows 11 (Build 22631.4602)
  • CPU: x64
  • File System: NTFS
  • User: Bamise
Scan Summary
  • Scan Type: Threat Scan
  • Scan Initiated By: Manual
  • Result: Completed
  • Objects Scanned: 263,197
  • Threats Detected: 4
  • Threats Quarantined: 0
  • Time Elapsed: 1 minute, 7 seconds
Scan Options
  • Memory: Enabled
  • Startup: Enabled
  • File System: Enabled
  • Archives: Enabled
  • Rootkits: Disabled
  • Heuristics: Enabled
  • PUP: Detect
  • PUM: Detect
Scan Details
Registry Key:
  • Detected: Trojan.Crypt
    • Location: HKLM\SYSTEM\CURRENTCONTROLSET\SERVICES\registryhost
    • Action: No Action By User
Registry Values:
  • Detected: PUM.Optional.DisableMRT
    • Location 1: HKLM\SOFTWARE\POLICIES\MICROSOFT\MRT|DONTOFFERTHROUGHWUAU
    • Location 2: HKLM\SOFTWARE\WOW6432NODE\POLICIES\MICROSOFT\MRT|DONTOFFERTHROUGHWUAU
File:
Other Items:
  • Processes: None
  • Modules: None
  • Registry Data: None
  • Data Streams: None
  • Folders: None
  • Physical Sectors: None
  • WMI: None
(End of Report)
Hello,
I have an i9-12900H, RTX 3090, 1000w PSU and 64 GB of ram. For a few weeks now, I have noticed that when I start my PC, the GPU (3090) runs hot, usually before I begin any task for that session. If I start any application or try looking through the Task Manager, it stops and returns to a normal idle temperature. Can anyone help me find a solution to this? Thank you😊
Edited by Bamise
To follow the rules properly
https://linustechtips.com/topic/1589433-gpu-running-hot-after-boot/
3 minutes ago, Bamise said:
sometimes has high has 70°C, enough to heat of my the air around my desk (and I live in a hot climate)
That's a bit on the higher end, but considering you live in a hot climate, it isn't all too bad.
Do your GPU's fans spin up during boot, and what's your idle temps?
Don't tell me to upgrade. I would've done so if I could.
  • 2 months later...
Conclusion
Log Details
  • License: Free
System Information
  • CPU: x64
  • File System: NTFS
  • User: Bamise
Scan Summary
  • Result: Completed
Scan Options
  • Memory: Enabled
  • Startup: Enabled
  • Archives: Enabled
  • PUP: Detect
  • PUM: Detect
Scan Details
Registry Key:
Registry Values:
File:
Other Items:
  • Processes: None
  • Modules: None
  • Folders: None
  • WMI: None
(End of Report)
