Hello!
Today’s PCIE lane video was very timely, as I am currently working through some issues and thought I would seek guidance from those of you who understand the black magic that is PCIE better than I do.
Background: I decided to take some parts I had around and finally make an Unraid server and consolidate some DAS’s into a proper NAS. That has expanded to running my Plex server and a VM for emulation.
Setup:
AMD 7950X3D
ASUS Prime B650M-A
X2 2TB SSD Gen 3 x4
64GB (32x2) DDR5
12 Sata 3.5 Drives (6 on expansion card 6 plugged directly into the board)
PCIE cards, in order top to bottom
Quadro P2000 (for Plex/Dockers)
PCIEx4 6 Port Sata 3.0 card
PCIEx4 10G Nic
3090 (for emulation Linux VM). This will be replaced by a 3060 or 4060 in the near future, just had the 3090 around so I decided to use it for a bit.
Currently only some of the Sata drives are detected, which is almost certainly a PCIE limitation. The 3090 is also not detected in its current port, works fine in the top port with a rise of course. I have it in the bottom slot since I need access to all four slots and the riser is tricky to make work in the rack chassis it is in.
My main questions:
Is there any way to make this setup work with this board? Even if that means maybe buying a x1 10G Nic instead of the x4 for example. I’m also open to ditching the Nic and using the onboard 2.5G if it’s the only option.
What is the best layout/order to put the cars in assuming I’m not able to use a riser?
Would upgrading to a different motherboard allow this setup work essentially as is? If so, what would be recommended? (The chassis fits ATX/MATX/ITX)
For anyone who made it through my rambling post, thank you!
https://linustechtips.com/topic/1585760-pcie-lane-help/
7 minutes ago, Mentuis said:
ASUS Prime B650M-A
Are you sure this is your motherboard? This one only has 3 PCIe slots, but you listed 4 cards. (and only 4 onboard SATA ports, you list 6 SATA drives to be connected to the mobo)
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1585760-pcie-lane-help/#findComment-16547876
1 minute ago, Mentuis said:
I probably neglected to add some identifier, it’s this board.
The default lane config of this board (with your CPU) is
Slot 1: PCIe x16 4.0
Slot 2: PCIe x1 4.0
Slot 3: PCIe x1 4.0
Slot 4: PCIe x1 4.0
This means that any card with a interface wider than x1 will only be able to run at full bandwith in slot 1.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1585760-pcie-lane-help/#findComment-16547893
5 minutes ago, Mentuis said:
Sounds like a new board is the answer then, which isn’t too surprising. Would it make sense to with with like a Strix X670E-E? Only three slots, but if I drop the 10G Nic that could work.
That board would be better suited, yes.
Lane configs:
Slot 1: PCIe x16
Slot 2: disabled
Slot 3: PCIe x4
m.2_3: disabled
Slot 1: PCIe x8
Slot 2: PCIe x4
Slot 3: PCIe x4
m.2_3: PCIe x4 or disabled
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1585760-pcie-lane-help/#findComment-16547909
