7800X3D temps
Go to solution Solved by JonS77,
seeing 60c while using light apps is normal. Just do a benchmark with CPU-Z, and cinebench and if your temps are in line with other online temps you see then you're good.
Hey all I finally got my entire upgrade minus the gpu thank you everyone who gave me advice. I just have a question about the idle temps for the cpu and what they should be my cooler is a be quiet pure rock 2 and my idle temps range from mid 40s all the way to high 60s is that normal or should I get a brand new cooler?
https://linustechtips.com/topic/1573007-7800x3d-temps/
Nothing seems out of place there. However you're learning nothing about your cooling solution effectiveness by looking at idle temps (we have to repeat this 10's of times a day).
HWiNFO and Cinebench multicore and then watch temps.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1573007-7800x3d-temps/#findComment-16433519
Thank you I’ll use that
https://linustechtips.com/topic/1573007-7800x3d-temps/#findComment-16433522
