Ps5 Troubleshooting Help!!
Solved by OhYou_,
solid white led is just normal, its booted and is waiting for you to set it up. If you have no display then it will be difficult to do so though.
I actually looked it up and yeah hdcp is on by default so you will have a bad time connecting it to regular computer monitors in some cases until you go in and switch it off using a display that does support it.
