Debian not recognize speaker
Go to solution Solved by g0ated,
It could be a unsupported driver have u tried using hdjackretask? and what audio server are u using?
It's AMD 4600G, I have tried different speakers and 2 headsets, but nothing shows up in the sound setting when I plug them in.
In the sound setting, it does show nomachine audio out and in when I connect to the PC using nomachine.
Not sure how to get the logs
Turns out, it is really bad to just use a hard drive that has Linux installed on a laptop (Intel CPU) on a PC with AMD CPU.
You miss all the drivers. hdjackretask worked
