Hi gang!
I am trying to rescue a BIOS but I can't my USB to work. SUPER TECH TIP FUN!
I have a Kingston DataTraveler. I have formatted it into FAT32 fine but it won't let me copy any files to it claiming it is write protected. Diskpart tells me it isn't write protected. I have reformatted a couple of times with no write protected errors, but still cannot move any files onto it.
Anyone seen this before? Any ideas?
https://linustechtips.com/topic/1560618-kingston-usb-write-protected/
If diskpart doesn't have the read only attribute set then it's probably because the Drive itself detected an error and put itself into a read-only state to preserve data. If this is the case then the drive is dead.
Steps To Clear The Read-Only Mode From Windows* Command Prompt Using Diskpart
