Budget ($3000 USD):
Country: Malaysia
Games, programs or workloads that it will be used for: After Effects, Premiere Pro, Blender and Photoshop.
Other details (Upgrading from a RTX 3060, intel i5 11400.):
I need feedback for this build, and if the motherboard is good or not, I don't think it supports bios flashback. I probably have to choose a different motherboard.
INTEL Core I9 14900K
ASUS Prime Z790-A WiFi 6E (DDR5)
Colorful Neptune RTX 4080 Vulcan-OC 16GB GDDR6
CORSAIR Vengeance 64GB (2x32GB) DDR5 5600MHz
SAMSUNG 990 Pro 1TB NVMe Gen4
SAMSUNG 980 M.2 NVME PCIE GEN 3 -1TB
FSP Hydro PTM X Pro 850₩ 80+ Platinum Full Modular PSU
NZXT H6 Flow RGB Compact Dual-chamber ATX Case with RGB Fans
Deepcool LT720 360mm AIO
NZXT F140 RGB Twin Pack (Black)
NZXT F120 RGB Duo Single Pack - 120mm (Black)
https://linustechtips.com/topic/1548881-help-with-a-pc-build/
An 850w PSU is okay but I would leave some room there and get a 1000w. Maybe a Corsair RMe or RMx.
Your choice of NVMe is a little odd to me, I would just get a 2TB 990 Pro, or the SN850x black. I don't know how much you're saving by getting the Gen3 drive. Your NVMe prices there might be a little too high, I would strongly suggest you look into getting them shipped from Amazon. Could arrive pretty fast and cost less. I know this for a fact.
The LT720 is one of the bests, but if you can spend just a bit more, I would get the Arctic LFII 420mm for that CPU. You could definitely make it work with the LT720, I like the Arctic since it cools it better but mainly because it's a lot more quiet. And then I would get a chassis like the Lancool III so it would fit the 420mm, that chassis comes with 4 decent 14cm Lian Li fans that are pretty good and quiet on lower RPMs.
And then if I have to buy better fans to replace them, I would get Arctic P14 fans instead of the NZXT ones.
https://linustechtips.com/topic/1548881-help-with-a-pc-build/#findComment-16258023
It this the ATX 3.0 version?
The motherboard doesn't have the Asus USB BIOS Flashback feature. You will have to verify the BIOS level before purchase. It is a decent motherboard although probably more expensive than needs be.
DDR5-6000 or higher would offer slightly better performance.
Since all the other RGB is NZXT, why not get one of its AIO?
The Samsung 980 Pro is PCIe 4.0.
https://linustechtips.com/topic/1548881-help-with-a-pc-build/#findComment-16258068
Budget ($3000 USD):
Country: Malaysia
Nvidia is due to release three new gpu's next month. Look at the reviews of the RTX 4080 Super 20GB.
https://www.techpowerup.com/316842/nvidia-geforce-rtx-40-series-super-review-schedule-and-availability-confirmed
https://linustechtips.com/topic/1548881-help-with-a-pc-build/#findComment-16258075
Yes
I see, gigabyte z790 aorus elite ax has it, is it good enough in your opinion?
Ok thanks.
NZXT KRAKEN ELITE 360mm is quite expensive, for the same performance as LT720, that's the reason.
I changed motherboard to gigabyte z790 aorus elite ax, Pretty sure gen 3 ssd works on it, but i'll change to gen 4.
https://linustechtips.com/topic/1548881-help-with-a-pc-build/#findComment-16260423
Okay, does the brand matters for PSU?
Thanks, I just realized what I did there, was dumb.
Alright, thanks.
Are the NZXT ones bad? And will it even fit the lancool III casing, or I would have to get a different fan?
https://linustechtips.com/topic/1548881-help-with-a-pc-build/#findComment-16260427
