Need help $2.5k USD build
Go to solution Solved by lecopperop,
8 hours ago, Hexxanite said:
Budget (including currency): $2500 USD (there is room for wiggle room like extra $100 or so) ( Roughly $4000 AUD)
Country:  Australia
Games, programs or workloads that it will be used for: Triple A title games and streaming at 1440P gaming
Other details: Don't need any peripherals, case, power supply or windows key my current psu is Corsair HX1200 also looking for nvme for boot and one for games my original thought was like Asus Prime Z790 or MSI pro Z790 Motherboard,  i7 13700k,  G.Skill Trident Z5 DDR5 CL30-34 range(32gb), 500gb Samsung 980 PRO and a 2TB, 4080 Asus ROG Strix and with some random Noctua NH-U9s cooler any thoughts or help or even changes I've never look at AMD stuff or thought about so no idea about AMD build ( also provide picture of what I was looking at prices are in AUD in total was like $3844)
Country:  Australia
to my knowledge  this is hands down the fastest system you could opt for at this price range while taking your notes in mind
https://pcpartpicker.com/list/qQvKcH
Country:  Australia
https://linustechtips.com/topic/1541624-need-help-25k-usd-build/
Since you're planning to use Intel 13700 paired with Z790, I would assume you wanna overclock to achieve true potential, which means you're gonna need a way more powerful cooler than NH-U9S
There are several alternatives, for air cooler, you will need a dual tower style, either Thermalright Peerless Assassin 120 for budget or Noctua NH-D15
But for maximum cooling, I would recommend AIO such as Arctic Liquid Freezer II 360, be Quiet! Silent Loop 2 360 or NZXT Kraken X73
Could you share the screenshot of PSU and PC case as well?
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
OK, but you can get a much better system for that price. https://pcpartpicker.com/list/sRfM34 13900KS + PNY 4080 + 2x16GB DDR5 5600 CL34 RAM and a Gigabyte AORUS ELITE AX Z790 Motherboard, along with a Noctua NH-D15 chromax.black and a Western Digital Black SN850X 4TB NVMe PCIe 4.0 SSD. Also your mentioned 100$ wiggle room has some extra options-
1. More Futureproof Z790
2. A "better" 4080?
3. Overkill extra 2x16GB Corsair matching Vengeance DDR5-5600 CL34 RAM.
AMD build- https://pcpartpicker.com/list/7WG3HG
Extra 100$ is almost the same options as the Intel build, except the motherboard is an X670 and the RAM is G.SKILL FLARE
Hope it help.
I don't have screenshots but here are links to the items PSU: https://www.corsair.com/us/en/p/psu/cp-9020140-na/hx-series-hx1200-1200-watt-80-plus-platinum-certified-fully-modular-psu-cp-9020140-na
Case: https://phanteks.com/Eclipse-P600s.html
2 hours ago, Hexxanite said:
Great, the PSU is a bit overkill, you can settle at 1000W, but if you're not tight on budget, it's not a bad choice
As for the case, Phanteks P600S is a nice case, quite modular and a lot of filter for front and top side
But, newer line up of PC case offer a better configuration (compatible 'air cooler' mode or AIO mode), even way modularity (top side has hinge which makes is way much easier to install AIO or PC fans on the top side) with a better price (USD 95-99)
You can try to take look at Lian Li Lancool 216
Here is a reference
Phone:
Here is a reference
Yeah the case is something I already have and the psu was bought in a big sale year ago so was like why not get it for a future future proof but then now with 40 series you want atx 3.0 or w/e so im stuck with it now just wanting to upgrade everything else now
Country:  Australia
Country:  Australia
