Help with PC build :)
Go to solution Solved by Why_Me,
@Svenofski What country are you located, what is your budget, what will be the primary uses of your PC and if it includes gaming then what is your monitor resolution?
If you're located in the US and your primary use will be gaming at 1440P then I would do something like this.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($298.79 @ Amazon)
CPU Cooler: *Deepcool AG620 67.88 CFM CPU Cooler  ($49.99 @ Amazon)
Motherboard: *MSI PRO B650-P WIFI ATX AM5 Motherboard  ($174.00 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($102.99 @ Amazon)
Storage: *Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.99 @ Adorama)
Video Card: *XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card  ($750.59 @ Amazon)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($86.99 @ Newegg Sellers)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $1678.33
Generated by PCPartPicker 2023-10-31 06:54 EDT-0400
A better look at those components.
https://lian-li.com/product/lancool-216/
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
https://www.msi.com/Motherboard/PRO-B650-P-WIFI
https://www.amd.com/en/products/apu/amd-ryzen-7-7700
https://www.deepcool.com/products/Cooling/cpuaircoolers/GAMMAXX-AG620-Dual-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
https://www.gskill.com/product/165/396/1673491242/F5-6000J3038F16GX2-FX5
https://www.crucial.com/ssd/p5-plus/CT2000P5PSSD8
https://www.xfxforce.com/shop/xfx-speedster-merc310-7900xt
If you're located in the US and your primary use will be gaming at 1080P then swap out the psu and gpu in that build with these.
https://www.msi.com/Power-Supply/MAG-A750GL-PCIE5
https://www.gigabyte.com/Graphics-Card/GV-R78XTGAMING-OC-16GD#kf
CPU: *AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($295.00 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Amazon)
Video Card: *Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ B&H)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Newegg)
Total: $1405.94
Generated by PCPartPicker 2023-10-31 07:36 EDT-040
What will you do with it ?
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16187832
Total: $1678.33
Total: $1405.94
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188246
12 hours ago, Svenofski said:
Dear Linus tech tippers.
Im a noob and im trying to build a pc. Is this PC any good? Do you have any suggestions?
Thanks.
https://pcpartpicker.com/list/6HY4pB
Yours truly, Svenofski Klichenheimer.
is it gaming? If so then try this
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($226.60 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($124.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($93.99 @ Newegg)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.99 @ Adorama)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card  ($750.59 @ Amazon)
Case: Phanteks Eclipse G300A (1 Fan) ATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fans 5-Pack  ($29.62 @ Amazon)
Custom: Windows 10 off SCDKey ($20.00)
Total: $1495.76
Generated by PCPartPicker 2023-10-31 06:14 EDT-0400
But if you can go up to $2000 then try this
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($369.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($189.99 @ Amazon)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  ($949.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF3 TT Premium 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($154.99 @ Amazon)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack  ($41.99 @ Amazon)
Total: $2016.82
Generated by PCPartPicker 2023-10-31 06:16 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188308
Total: $1495.76
Total: $2016.82
yeah probably shoudn't pair a ryzen 5 with 7900xt, it might be bottleneck in some cases
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188310
Not at 1440p, not even that much at 1080p since the 7600 is basically a 5800X3D image.thumb.png.8eaf08c6c82b3f3305d2b1ac5aa4f859.pngimage.thumb.png.ff1d453316a2817fd82786d87aab62da.png
Total: £1040.95
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188332
Total: $1495.76
Total: $2016.82
You have $84 in case fans for a $35 case. A case that isn't normally recommended other than > $700 budgets.
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188496
but it's a good case, why can't it be used here?
so? more fans = more betterer right?
Total: £1040.95
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188546
If u can go with a little bit higher budget try this:
https://pcpartpicker.com/guide/Cxqqqs/magnificent-amd-gamingstreaming-build
Etiher with the 4070 ti or the 7900XT, if u need to spend some less maybe a 4070?
I'm sorry if i made any spelling mistakes, i'm not an English speaker.
Ryzen 7 5700G @ 4.2GHz All Core. Aorus Elite V2. 2x8Gb 3600MHz CL17. Nfortec Aegir X. Nfortec Nervia.
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188574
Total: $1678.33
Total: $1405.94
thanks, ill read this and ponder
https://linustechtips.com/topic/1538450-help-with-pc-build/#findComment-16188740
