17 minutes ago, trikooasks said:
Is there a software that i can use on my android phone to make a bootable usb drive so i can install linux on my computer?
My computer has no operating system in it
There might me a version of rufus on android although personally wouldn't really recommend it since yeah play store does have some sus programs there ngl so yeah try finding a separate pc and do the desired installation through there. Hope this helps
28 minutes ago, ItsDestini said:
Try seeing if drive droid does the job and also if its reliable since I've just discovered it
This app requires root, i guess borrowing a pc is less of a headache than rooting my device (which also requires a pc) to make a bootable usb drive.
