Recently upgraded from X79 to my new system 2 months ago. Im am using the same GPU and PSU as on the old system. I was playing a game when the screen froze(still displaying image) and it gave me the angry buzzing noise and a hard crash. I held down power button untill it rebooted and my PC did not post. The motherboard CPU LED lights up solid red which means something is up with the CPU(according to the manual). When turned on it does not post but the motherboard chipset, NVME drive, and cpu heat up as if its working. Ive tested the CPU 8 pin connector on my psu and its delivering 12V. No CPU overclocks or voltage changes, BIOS was with stock settings except for DRAM speed which was set manually to 6000MT/S, no voltages were changed. Should note that both XMP profiles crashed and would force a reboot hence manually setting the speed. GPU was overclocked to 2050 Mhz but it still works fine. All temps were good.
Already disassembled/re assembled cleaned out connectors/slots, tested RAM individually and GPU, cleared cmos, remounted cpu, checked all the pins, cleaned off the bottom of the cpu with a tiny amount of IPA and a microfiber cloth.
Have functional X79 components to test PSU and GPU on.
PC components
I7-12700KF
Gtx 1060 3gb
Asus rog stix z690-g
2*16GB G.Skill Trident Z5 DDR5 6400MT/s
Dagger Pro 650W
WD SN850X 1TB
Faulty CPU's are pretty rare so any additional troubleshooting suggestions before I fork out money for a new processor are appreciated.
https://linustechtips.com/topic/1523114-pc-wont-post-gives-cpu-error/
Try outside the case and only using the most essential parts.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
