1 minute ago, Vibora said:
Hey guys, what are your thoughts on this bend? Is it reasonable / ok?
Pic 1 Pic 2
Page can't be found
But just some advice make sure the cable is in all the way
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16027747
Jus edited and added the pictures, what do you think?
Seems ok but it looks like you can push it in a bit further. Can you? If not then try taking it out and plugging it back in. You might need to use some force
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16027760
Pretty sure its plugged all the way in but ill try again, thanks
Come back here and tag me when its done
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16027764
Just now, Vibora said:
Just did again, it clicked 🙂
Then it should be good. have you turned on the computer? It should work. I'd also do a stress test like furmark to see its performance and stability
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16027775
Not yet, got to do a few things before, first thing is im going to the bios and ill check cpu and gpu temps.
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16027778
Ran furmark on the 1440p preset, no crashes or anything, hows this score?:
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16029710
Seems good. I think you’re ready to go into some of your games. Just report back with any performance numbers
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16029742
So I tried RDR2, 1440p, everything ultra and I hit between 60-80. maybe 90 sometimes which seems too low for 1440p. Ill try other games later when I have time
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16029803
You've installed all your drivers right? Also what cpu do you have?
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16029806
9 minutes ago, Vibora said:
Of course, latest. I paired it with the 13700k
Your right its a bit weird since this youtuber got 115 fps at 4k native
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16029824
I checked the task manager after and I have seen that the gpu usage was at 100% so that's even more weird
How was power usage on the 4090?
Total: £1040.95
https://linustechtips.com/topic/1518633-4090-cable-bend/#findComment-16029919
