I’ve got all my parts with a EK nucleus cooler for the top of my Lian li o11 case. However I have 3 fans currently with another 3 arriving in a week and a half however for the current time what would the base 3 fan setup be for the Lian li o11. If computer parts are needed/ wanted pls let me know.
https://linustechtips.com/topic/1516305-fan-placement/
3 intake on the side, with the nucleus AIO set to push from the inside of the case to exhaust.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1516305-fan-placement/#findComment-16010998
The EK Necleus AIO I am not versed with.  The ideal location for an AIO in a Lian Li 011 Dynamic is the top panel mount. If putting in the right side mount, place it so the tubes of the radiator are on top and above the CPU block / pump, so air does not become trapped at the pump.
I have in my Lian Li  011 Dynamic Razer Edition case, 3x 120mm fans on the right side mount (beside motherboard) setup as Intake ; and 1x 120mm fan on the case bottom as Intake as well... 4x fans for Intake.
The Corsair H150i exhausts airflow through the top... hopefully giving a Positive Pressure scenario of cool air.
That a few Youtube computer builders advised when reviewing the case for AIO equipped builds. I've tried it and it works well.
You may want to consider using a software based fan / rgb controller hub.... I use a Corsair Commander unit.
Intel Core i9 10920x CPU; ASUS ROG Strix x299-E Gaming II Motherboard; 64 GB Corsair Vengeance LPX DDR4 3200 MHz Quad Channel Kit; EVGA RTX 3070 XC3 ULTRA Gaming 8 GB; 2 TB Samsung 970 EVO Plus NVMe m.2 SSD & 1 TB Samsung 970 EVO Plus NVMe m.2 SSD; 1 TB WD Blue SATA SSD; 2x 6 TB HGST DeskStar NAS Hard Drives; Corsair iCUE H150i RGB PRO XT All In One Cooler; Corsair RM1000x 1000 Watt PSU; Corsair Commander Pro Lighting & Fan control; 4x Corsair HD120 RGB 120 mm fans - Intake ; Lian Li 011-Dynamic Razer Edition cube case, Windows 11 Pro 24H2
https://linustechtips.com/topic/1516305-fan-placement/#findComment-16012220
