Help, Gpu too tall
Go to solution Solved by Supersonicwolfe,
Loosen up the PCI-E slot screws, plug in DP and then tighten the screws
I need some help, i just bought a MSI RX 6800 GAMING Z TRIO, and found out that it's like 2mm too tall, so my Displayport cable cannot connect properly, and I don't dare to turn it on to try to see if it works. Any tips or maybe know what I did wrong to make it not fit? The case is NZXT h510. I had a RX 5700XT before, and I got no problem with that
https://linustechtips.com/topic/1514266-help-gpu-too-tall/
Due to some loose tolerances, you should be able to shift the GPU a tiny bit downward to accommodate the output ports, and it's not gonna place a bunch of strain on the PCIe slot.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1514266-help-gpu-too-tall/#findComment-15995084
Thanks for the tip! I'm very new to this, but I carefully lowered the graphics card and tightened the skrew as sson the angle is right 👍
https://linustechtips.com/topic/1514266-help-gpu-too-tall/#findComment-15995158
