Will there be issues with this drive arrangement?
Solved by adm0n,
As long as you are not changing anything, it will be fine. Ideally you'll try to shrink your current C volume and create a new partition from the unused space. That way, you don't accidentally mess anything up.
But otherwise it is no different than having two OS's on your current computer and the drive showing up in both of them. There is nothing magical that changes, when you put it into another PC.
