Pc won't power on
Solved by Randomrandom333,
On 5/6/2023 at 8:31 PM, Randomrandom333 said:I'll try swapping the motherboard out for the MSI one and see if that works
Update: I found out the issue was that the 24pin connector wasnt in all the way and the molding on the PSU cable wasn't letting it go in. I got a cable mod extention cable and it clipped into the motherboard and booted up.
RipperDoc5456 ·
Posted in Troubleshooting2 -
Nebcs ·
1
FancyPants101 ·
l3eyond ·
1
