I want to use this case (MODECOM VOLCANO AMIRANI ARGB) will the other parts fit
RTX 4070
i7-13700K
CoolerMaster MASTERAIR MA621P TR4 EDITION
Kingston 32GB 6000Mhz (X2)
Asus prime z790-P
Cooler Master V750 Gold V2
Kingston 1000GB Nv2 SSD (X2)
https://linustechtips.com/topic/1504798-will-they-fit/
wich 4070
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923582
check the length of gpu, rest should fit
Setup:
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923584
RTX 4070
i7-13700K
Asus prime z790-P
The CPU cooler is for a Threadripper CPU (TR4). The motherboard is for an Intel 12th or 13th gen Core CPU. They are fundamentally incompatible.
The CPU cooler is 165mm tall which is the maximum height allowed in the case specs. Depending on manufacturing tolerances, the cooler may touch the case side.
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923601
I found another one this one should fit right?  Cooler Deepcool AK400 Zero Dark
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923603
1 minute ago, Reckless45 said:
This one ASUS DUAL-RTX4070
bro it says the max length is 380mm
u can easily take a quick look at the description
but yes
it will fit
even tho i have no idea why you would EVER go with a gpu that bad
Setup:
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923606
please mark as solved
Setup:
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923609
The AK400 will fit and is compatible. It is marginal for cooling an i7-13700K. An AK620 would be better but check the height of the memory modules as that cooler restricts memory height to 43mm.
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923617
but yes
it will fit
In your opinion which gpu is worth for 650€ and is better than the 4070
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923620
the 4070 isn't bad for power efficiency but the 6900 xt is better. Then again if your paying a lot for energy I would get the 4070
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923621
Just now, Reckless45 said:
In your opinion which gpu is worth for 600€ and is better than the 4070
6950xt can be found for that price, the 4070 lack of vram is horrid and will make it obsolote probably within the next year and a half, seeing the upcoming games, its just a laughingstock, get something with at least 12gb of vram (6950xt is on par if not better than 3090ti), you can also get a 6800xt, 16gb vram and performs well and better for about 500 or 450 in my country
Setup:
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923623
only problem with that is its power draw and the high energy prices in europe. I would get the 6900 xt instead as it draws 70 less watts but only performs slightly worse for less
Total: £1040.95
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923624
true
Setup:
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923628
Okay, thanks i will look for it
https://linustechtips.com/topic/1504798-will-they-fit/#findComment-15923630
