Need help making a new build
Go to solution Solved by PDifolco,
52 minutes ago, (Reggie_EU) said:
Budget: £900 - £1000
Country: UK
Games, programs or workloads that it will be used for: This PC will be used for programming in C# and making games in Unity as well as gaming. The games I will be playing are; Elden ring, Rust, Ark,  Diablo 4, World of Warcraft.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): So I want to be gaming at 1440p with good frame rates. My old PC had its PSU blow up and take everything with it. That build was a Ryzen 1700 and a GTX 1060 6GB. I don’t mind buying a used GPU to save some money as GPU prices are a little bit nuts. Open to any suggestions and don’t have any company preferences. I already have a CPU cooler but I need to get everything else thank you for your help
A part list I have put together: https://uk.pcpartpicker.com/user/Reggietheslow/saved/bkbnpg
Learn from mistakes, get a good PSU rather than a mediocre one with large power
And if you're in computation an Intel build would make more sense at those prices
PCPartPicker Part List
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  (£239.97 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B760M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  (£148.97 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£38.53 @ Amazon UK)
Storage: Kingston NV2 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£77.48 @ Amazon UK)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card  (£359.99 @ Scan.co.uk)
Case: Fractal Design Meshify C ATX Mid Tower Case  (£60.00)
Power Supply: Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£109.98 @ Scan.co.uk)
Case Fan: Phanteks PH-F120SK 50 CFM 120 mm Fan  (£8.99 @ Amazon UK)
Total: £1061.89
Generated by PCPartPicker 2023-04-26 13:46 BST+0100
Country: UK
https://linustechtips.com/topic/1503159-need-help-making-a-new-build/
Don't repeat past mistakes, https://cultists.network/140/psu-tier-list/.
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (£125.97 @ Amazon UK)
Motherboard: Gigabyte B550 GAMING X V2 ATX AM4 Motherboard  (£108.48 @ Amazon UK)
Video Card: Gigabyte GAMING OC Radeon RX 6800 16 GB Video Card  (£479.99 @ Newegg UK)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  (£54.99 @ AWD-IT)
Total: £972.41
Generated by PCPartPicker 2023-04-26 13:17 BST+0100
Thats the lowest I would go for the PSU, the GPU is better and for gaming the 5600 is better value in my option and it's a good match with that smaller cooler. I have the 5600 (with a little OC) paired with a 6800XT and I don't run into any bottle necks at 1440p ultrawide
Total: £972.41
Thank you. My only concern is the with the CPU. As a programmer my PC will be performing a lot of computational tasks which is why in the original parts list I had a better cpu and a worse graphics card
Use the stock cooler.
Motherboard: Gigabyte B760M GAMING X DDR4 Micro ATX LGA1700 Motherboard  (£124.94 @ Amazon UK)
Case: Montech AIR 100 ARGB MicroATX Mid Tower Case  (£49.94 @ CCL Computers)
Power Supply: Fractal Design Ion Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£94.99 @ AWD-IT)
Total: £985.84
Generated by PCPartPicker 2023-04-26 13:42 BST+0100
Country: UK
Total: £1061.89
Total: £1061.89
Yes, thank you so much. I will definitely do some more research into power supplies. I have been looking at the I5 but the extra £65 feels rough. After doing some more research on it though it might be worth it. I won't be buying the parts for this PC until late May so I have some time to think it over. Glad to see most of my other choices are okay though
