Title doesn't match post. TV has opened, after you got yourself a screwdriver (or hammer?).
Considering all the information you shared, I suspect just low FPS with your eyeballs.
Might want to include TV model and whatnot. I bet Samsung made several 75" TV's.
What did you try to do, before you got your screwdriver/hammer out? What was it connected to? What was the previous behavior, while it worked just fine?
(can't be more helpful, haven't owned a TV in well over 10+ years)
https://linustechtips.com/topic/1499770-tv-not-opening/#findComment-15885435
dude chill man. Im a general repairer and its a customer that trying to fix his tv. Im just not good with tv's but I repaired backlights and other stuffs. just dont know if the problem is motherboard, psu or TCON
https://linustechtips.com/topic/1499770-tv-not-opening/#findComment-15885440
