Posted April 8, 2023 Goodday! I am looking for a wireless tenkeyless mechanical keyboard with backlighting, media controls and long range (2 meters max when using it in the living room) and I need your help picking one. So far, the only keyboards I found that met my requirements are the Logitech g915 and the razer Razer DeathStalker V2 Pro. I watched reviews for both keyboards and read several threads and articles about them but I still can't decide. On the one hand, the logitech has twice the battery of the razer and can still maintain its wireless capabilities even when it's charging which would make it the only choice for me but from what I hear the keycaps are the worst and not even close to the quality standards you should expect from a 200€ keyboard. There are cases of keycaps breaking or even the letters fading out over time cause of the awful paint they used. Worst part is that it's extremely difficult to find replacement keycaps... Is the razer a better choice in my case even though the battery is smaller and it cannot be used wireless when it's charging? I am also open to suggestions so if you have something else to recommend I would be happy to hear it! Thank you in advanced, Kostas Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2023 42 minutes ago, K0stas said: On the one hand, the logitech has twice the battery of the razer and can still maintain its wireless capabilities even when it's charging which would make it the only choice for me but from what I hear the keycaps are the worst and not even close to the quality standards you should expect from a 200€ keyboard. There are cases of keycaps breaking or even the letters fading out over time cause of the awful paint they used. Worst part is that it's extremely difficult to find replacement keycaps... 40 hour battery life isn't bad, it can just be inconvenient at times if you forget to charge it every 1 or 2 nights. Keycaps breaking or fading out is bad. REALLY bad. So my personal recommendation is the Razer DeathStalker. Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/#findComment-15883692 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2023 Author 2 hours ago, bluraydisc said: 40 hour battery life isn't bad, it can just be inconvenient at times if you forget to charge it every 1 or 2 nights. Keycaps breaking or fading out is bad. REALLY bad. So my personal recommendation is the Razer DeathStalker. Thank you for replying! I have never used a wireless keyboard before so I don't know if the battery life will be any inconvenience at all. It's good to hear that 40 hours is not that bad. Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/#findComment-15883807 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 12, 2023 A wireless keyboard is an essential piece of equipment for a tidy workplace. It should have a long battery life,dependable connection, comfortable typing, and creat a comfort device. Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/#findComment-15888443 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 13, 2023 On 4/12/2023 at 8:07 AM, bibac said: A wireless keyboard is an essential piece of equipment for a tidy workplace. It should have a long battery life,dependable connection, comfortable typing, and creat a comfort device. Good things to include in one but there’s no suggestion. On 4/8/2023 at 3:13 PM, K0stas said: Goodday! I am looking for a wireless tenkeyless mechanical keyboard with backlighting, media controls and long range (2 meters max when using it in the living room) and I need your help picking one. So far, the only keyboards I found that met my requirements are the Logitech g915 and the razer Razer DeathStalker V2 Pro. I watched reviews for both keyboards and read several threads and articles about them but I still can't decide. On the one hand, the logitech has twice the battery of the razer and can still maintain its wireless capabilities even when it's charging which would make it the only choice for me but from what I hear the keycaps are the worst and not even close to the quality standards you should expect from a 200€ keyboard. There are cases of keycaps breaking or even the letters fading out over time cause of the awful paint they used. Worst part is that it's extremely difficult to find replacement keycaps... Is the razer a better choice in my case even though the battery is smaller and it cannot be used wireless when it's charging? I am also open to suggestions so if you have something else to recommend I would be happy to hear it! Thank you in advanced, Kostas out of the two the g915 Message me on discord (bread8669) for more help Quote me if you want me to get notified Current parts list: PCPartPicker Part List CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (Purchased For £175.00) CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler (Purchased For £0.00) Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard (Purchased For £144.99) Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (Purchased For £89.99) Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (Purchased For £0.00) Storage: Kingston A400 960 GB 2.5" Solid State Drive (Purchased For £0.00) Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card (Purchased For £448.99) Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case (Purchased For £82.98) Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply (Purchased For £99.00) Total: £1040.95 Damn this space can fit a 5090 (just kidding, it needs more) Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/#findComment-15891053 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 18, 2023 On 4/14/2023 at 1:37 AM, filpo said: Good things to include in one but there’s no suggestion. out of the two the g915 I have no big idea. But I think Keychron K10 can bring a good result for you. Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/#findComment-15897755 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 19, 2023 Author On 4/18/2023 at 9:29 AM, bibac said: I have no big idea. But I think Keychron K10 can bring a good result for you. Looks like a great keyboard, it's even customizable and cheap but it's missing media controls which are essential for my use-case Link to comment https://linustechtips.com/topic/1499499-wireless-keyboard-recommendation/#findComment-15899654 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
