Budget (including currency): 800€
Country: Germany
Other details: Corsair RM850 PowerSupply, Asus Prime X470 Pro Motherboard, Ryzen 2700x, 2x8 GDDR4 RAM 3000mhz, Gigabyte 4070 ti gaming OC, Fractal Design North Case
Sooo, I am currently upgrading my setup and those things on top are my current things + things I'm about to buy (not in the budget, bought differently)
I would need some new parts like a CPU which could handle the new grafics card, maybe more/faster RAM and probably an AIO water cooling solution for the CPU. (Don't know if I should upgrade the Motherboard because it's still quite compatible, at least that's what I've read)
https://linustechtips.com/topic/1498165-need-some-helpadvice-for-components/
1 minute ago, Failure 101 said:
I would do something like this https://de.pcpartpicker.com/list/JMM7Q6 and spend the rest on maybe a 4080
personally i would go with the 7900xtx instead if it is cheaper where you live
5 hours ago, Ombiax said:
also +340 here
And Nvidia is more suitable for AI generation and stuff like that
Then you shouldve mentioned that, the purpose of the build. LTT demographic is a bunch of gaming nerds, so they will default to that. But even then, id definitely cross shop the 4070Ti with the 3090 on used market which would double your VRAM, or eating the cost bump for a 4080.
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  (€343.99 @ Mindfactory)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (€42.90 @ Amazon Deutschland)
Motherboard: Asus Prime X470-Pro ATX AM4 Motherboard  (Purchased For €0.00)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€70.90 @ Alza)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€128.97 @ Galaxus)
Case: Fractal Design North ATX Mid Tower Case  (Purchased For €0.00)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For €0.00)
Total: €586.76
Generated by PCPartPicker 2023-04-02 06:00 CEST+0200
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I feel personally attacked  In all seriousness thats a good list only thing i might add is he may not need a extra 2tb of nvme
Total: €586.76
Already have an M.2, just forgot to mention it, sorry.
Yes, I should have told you the usecase of the build, also my bad.
Used grafics cards are pretty wanky on the German market. Literally like a 50/50 gamble of beng scammed and stuff like that, so I would stay with a new one. And is it really worth putting in +400 for the 4080?
