It realistically should be thermal throttling before it reaches temperatures that are too high. Are all the fans functional? It looks like hotspot temps for those cards tend to be pretty high from what I can see.
This could also be exaggerated by the ambient temperature in the room that you're in as well. How high are the VRAM temps?
hi thank you for your reply! sorry for the delay i was really busy at work. i made a mistake actually my hotspot temp according to gpu z is 70c and the memory temp is 82. what should i do?
