11 minutes ago, Tibby said:
Which way should I go?
AMD Ryzen 7 7700, DDR5 RAM 6000 mhz CL30, RX 6900XT
Intel i5-13600k, DDR4 RAM (lower CL and mhz), RX 6900XT
Depends what your doing with it, general purpose they're both fine. what games? (if any) what software?
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1491811-need-opinions/#findComment-15826969
Just general gaming, rocket league, cod, fortnite, simulator games and gta. in terms of software i wont be using many intense software
https://linustechtips.com/topic/1491811-need-opinions/#findComment-15826979
7700 games a little better at stock values especially vs. 13600k with DDR4. If you're just gaming the 7700 makes more sense but you should prob wait a month for the 7800X3D.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1491811-need-opinions/#findComment-15827020
Just now, Tibby said:
what motherboard should I get for it
one with bios flashback for sure, but i would think anything that would work with a 7700 would also do well with a 7800x3d
https://linustechtips.com/topic/1491811-need-opinions/#findComment-15827213
