Need help tweaking a pc build
Go to solution Solved by PDifolco,
37 minutes ago, Fujka293 said:
Budget (including currency): about 700$
Country: Czech Republic (probably buying from German Amazon)
Games, programs or workloads that it will be used for: Mostly games (1080p), but also PC virtualization
Other details: I have a 60hz HD monitor and I just need help with tweaking the parts so I  don't over/under spend on anything
Processor: AMD Ryzen 5 5600 (6 cores, 12 threads, 3.5-4.4 GHz)
Graphics Card: MSI AMD Radeon RX 6650 XT 8G
Motherboard: The Gigabyte B550M DS3H Micro ATX AM4 (4 Ram slots Up to 128 G, 2 m.2 slots)
Memory: Corsair Vengeance LPX High Performance 2 x 8 G
Storage: Crucial P3 Plus 1 TB CT1000P3PSSD8 PCIe 4.0
Good, you got the best price/perf parts atm on that budget
https://linustechtips.com/topic/1490682-need-help-tweaking-a-pc-build/
If that's what you got then nope, everything does in fact look good. Unless you need wifi, then change that motherboard to the wifi version. 🙂
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
