OHI!
I'm currently in the market for a SSD. I'm looking for a 240G+ drive for 200USD or lower. I have been shopping around and reading as much as I can. Just want to know what my best options are in real world scenarios. Any constructive feedback will be much obliged.
Also, upgrading from a 500gb momentus xt Hybrid drive. How much of an upgrade will a new SSD be?
Thanks in advance!
https://linustechtips.com/topic/14881-need-help-with-new-ssd/
Hi there,
Great to see that yet another one going to the SSD side! I think it's a great worth of value, personally I use the OCZ Vertex 4 and the Samsung 840 Pro. Neither of them ever disappointed me.
Comparing read/write speed from something like the Crucial m4 to the Vertex 4 or the 840 Pro, the difference is in the write speed.
Dutch forum Tweakers.net says this about the Crucial m4 (128 GB) under the tile: Crucial m4: King Under the SSD's
"Looking at the price of the Crucial m4, not only is is the fastest SSD in it's class but also very beneficial. The Corsair Force 3 and the older drives like the OCZ Vertex 2 might be lower in price per gigabyte, but they offer less then 2/3 performance that the m4 can give you. Other good performing SSD's like the OCZ Vertex 3 and the Corsair Force GT are per gigabyte at least 20 procent more expensive. The makes the choice for tweakers' that are looking for a fast SSD with a capacity of 120 - 128 gigabyte very simple: the Crucial m4 is the fastest and at the same time one of the cheapest."
I think this SSD has great value!
1http://tweakers.net/reviews/2284/5/crucial-m4-koning-onder-de-ssds-conclusie.html
Greetings from the Netherlands!
Asus Sabertooth Z77 - Intel Core i7 3770K - Corsair Dominator Platinum 2133 MHz 8 GB
https://linustechtips.com/topic/14881-need-help-with-new-ssd/#findComment-166527
Your best bet is probably a 250GB Samsung 840.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/14881-need-help-with-new-ssd/#findComment-166754
