On 1/19/2023 at 1:39 AM, Dukesilver27- said:
Upgrade your GPU to what?
Also,  proprietary PSU usually means the PSU shroud/mounting place is not for standard PSUs, so check that.
i wanted a 3070 or 3080 and im not sure how to check the shroud
Yea you're gonna need at least 750W PSU.
Open the case and see if the PSU looks standard, compare them to pictures online. Or measure the available space for the PSU in the case.
Occassionaly visits the forum when I have nothing to do at work.
