Budget (including currency): Roughly $2000 USD, give or take 100-200 dollars (separate budget for peripherals)
Country: USA
Games, programs or workloads that it will be used for: Currently playing Rainbow Six Siege, Minecraft, Monster Hunter, MW2, a lot of excel, studying game design and coding on the side as well (I am a CompE. major.)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Never had my own PC and have never assembled one. I know I'll have to dedicate a good portion of time to assemble it but I am not too intimidated by the task. I have most recently been looking into building a PC using AM5, which I am aware is very new and mobo and ram are quite expensive, let alone the CPU. I am hoping to get the Ryzen 7 7700X, and luckily I am only about 10 miles away from a MicroCenter, who are giving a deal for free 32gb of DDR5 ram if I were to purchase the R7 7700X, so that would save 150-200USD. If I were to go with an AM5 build and this specific CPU, what would be an ideal GPU? I am well aware about prices rn, so I will be taking that into account. The 4070 ti released very recently, but I have seen very mixed opinions on it. 4080 would have been great, but I can't find any decently prices ones. Any other options, I know AMD has some options as well. I wish to play on 1080p most of the time, mayybeee 4K if its something like Monster Hunter. I might buy a 144hz monitor I'm not sure. Also any help with cooling options? I legitimately do not know what to go with. This is my first ever forum post, thanks for the advice!
https://linustechtips.com/topic/1479855-gpu-recommendation-for-future-build/
Country: USA
This Pc is pretty good! If you wanted to play Minecraft with ray tracing the RTX 4070ti will handle it well. This pc should last you for a long time. I added RGB fans. If you don't want RBG then here is some other options
https://pcpartpicker.com/product/LmCFf7/arctic-p12-pst-563-cfm-120-mm-fans-5-pack-acfan00137a
make sure to get its fan hub
https://a.co/d/23vD8aV
Productivity and gaming is balanced with this PC but it's more optimized for gaming! Productivity will be great too!
PCPartPicker Part List: https://pcpartpicker.com/list/hV36bK
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($344.99 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($89.90 @ Amazon)
Motherboard: Gigabyte B650M AORUS ELITE AX Micro ATX AM5 Motherboard  ($199.99 @ Amazon)
Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Amazon)
Video Card: Zotac GAMING Trinity OC GeForce RTX 4070 Ti 12 GB Video Card  ($899.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($189.99 @ Amazon)
Case Fan: Antec Prizm 5+C 45.03 CFM 120 mm Fans 5-Pack  ($59.95 @ Amazon)
Keyboard: Keychron K2 Hot-swappable Wireless Gaming Keyboard  ($89.99 @ Amazon)
Mouse: Logitech G305 LIGHTSPEED Wireless Optical Mouse  ($34.99 @ Amazon)
Headphones: Razer Barracuda X (2021) 7.1 Channel  Headset  ($54.99 @ Amazon)
Total: $2094.77
Generated by PCPartPicker 2023-01-08 10:19 EST-0500
Total: $2094.77
I just realized 1000 watts is overkill oops!
750-850 psu should be enough!
850 watt psu
https://pcpartpicker.com/product/26rRsY/corsair-rm850x-2021-850-w-80-gold-certified-fully-modular-atx-power-supply-cp-9020200-na
750 watt psu
https://pcpartpicker.com/product/6NcG3C/corsair-rm750x-2021-750-w-80-gold-certified-fully-modular-atx-power-supply-cp-9020199-na
Give 200 dollars
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($308.69 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 White 66.17 CFM CPU Cooler  ($46.36 @ Amazon)
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard  ($199.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($49.99 @ Amazon)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: Gigabyte GAMING OC GeForce RTX 4080 16 GB Video Card  ($1269.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($104.99 @ Amazon)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($137.99 @ Amazon)
Total: $2197.98
Generated by PCPartPicker 2023-01-08 11:35 EST-0500
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
7 hours ago, greeatzy said:
Give 200 dollars
Total: $2197.98
Thanks so much for the advice! I've heard great things about 13th gen for intel, and it'll allow for me to buy a mobo that's 200 or below and cheaper ram. Unfortunately 4080 is def expensive, but I'm not surprised. Thanks a lot!
8 hours ago, COOLmonke14 said:
Thanks so much for the help! I'll look into the parts you recommended!
