Hi there,
I was trying to use AMD Link to stream games from my PC to my Notebook.
These are the used versions:
Notebook - Win11 - current AMD Link software installed on 28.12.2022 via the Microsoft Store
PC - Win10 - R9 390X - Radeon Software 22.6.1
When entering the correct information shown on the server side, it displays an IP error.
Does anyone has experienced the same issue or is there any way to get more detailed information for troubleshooting?
Thanks,
Lukas
https://linustechtips.com/topic/1478168-amd-link-issues-connection-not-possible/
  • 2 months later...
I have the same issue. It works from time to time but never reliably. It's great when it works but it only works half the time. I wish I had a solution for this as well... Parsec is a great alternative but at least for me AMD link seams to have less latency.
