Budget (including currency): 3000 gbp
Country: UK / England
Games, programs or workloads that it will be used for: Just gaming 1440p 240 fps + (ik the budget is overkill but allow it)
Other details I currently have a list of parts I know I want just not sure about some others
Gpu 7900xtx
CPU i9 13900k
32gb ddr4 3600mhz
Motherboard (possible ASUS PRIME Z790-A WIFI)
Powersupply  - Just going for a reputable brand and for a 1000 watt version.
Cooler for cpu will be a duel radiator.
Case - No clue so any help
M.2 ssd 1tb - not sure what m.2 to get so help here would be nice Budget of like £70 - £100
https://linustechtips.com/topic/1476876-my-possible-pc-build-plan/
Gpu 7900xtx
CPU i9 13900k
32gb ddr4 3600mhz
So something like this: https://uk.pcpartpicker.com/list/2hBpY9
There have been a few issues with AMDs reference design 7900xtx cards from what ive heard so going with a 7900xtx with a different design to the reference one might be a safer option. You might want to consider a 360mm AIO or a 280 instead of a 240 (im assuming you mean a 240mm aio when you say duel radiator and not a dual tower air cooler, the 240mm ive put in the parts list is just there as a placeholder).
The case really depends on which case you like the look of, but try and go for something with some airflow. Ive put in a 4000D airflow as a placeholder, its a great case (ive got one myself) and a lot of people like how they look, but other options are avaliable.
For the SSD there are a few options that all have simmilar specs for a simmilar price:
Crucial P5 plus
WD SN850x
Kingston fury renagade
or if you want to save some money a WD SN770 is a good mid range option or a SN 570 is a good budget option
System: AMD R7 5700g (OC to 4.45GHz fixed clock) / Noctua NH-D15 / Gigabyte B550 Gaming X V2 / Gigabyte Waterforce WB RTX 2080 Ti / Crucial 4x8GB DDR4 (OC to 3800MHz Cl16) / 1TB Samsung 970 Evo Plus / Corsair 4000D airflow / Corsair TX650M / BenQ Mobius EX2510 24.5" 1080p 144Hz
Crucial P5 plus
WD SN850x
PCPartPicker Part List
CPU: Intel Core i9-13900K 3 GHz 24-Core Processor  (£589.50 @ Technextday)
CPU Cooler: ARCTIC Liquid Freezer II 360 A-RGB 48.8 CFM Liquid CPU Cooler  (£127.37 @ Technextday)
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard  (£179.99 @ Amazon UK)
Memory: Kingston FURY Renegade 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£96.20 @ CCL Computers)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£129.98 @ Scan.co.uk)
Video Card: Gigabyte GAMING OC Radeon RX 7900 XTX 24 GB Video Card  (£1191.80 @ Technextday)
Case: Fractal Design Meshify 2 Compact Lite RGB ATX Mid Tower Case  (£110.59 @ CCL Computers)
Power Supply: NZXT C1000 (2022) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£139.99 @ Amazon UK)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack  (£32.39 @ Amazon UK)
Total: £2597.81
Generated by PCPartPicker 2022-12-27 22:08 GMT+0000
NZXT aio aren't the best a better option would be a artic or ek aio
If OP is spending 3k on a pc he might want rgb and have more the n1tb of storage
Thanks a lot I will most likely be going with something like / just this. So thanks a lot and for saving me a bit of cash
Also 1 thing I did forget to say is I will most likely be buying just 2tb 7200 rpm hard drive for things i wont use much.
