Should I upgrade?
Go to solution Solved by An0maly_76,
As stated, your budget is the limiting factor here. Even with a budget upgrade of an i5-10400 and a good midlevel LGA1200 board, you're looking at $256 USD, or 239 euro. This is assuming, of course, that an LGA1200 board can use all of your existing components (RAM, CPU cooler), and then you'll still have to upgrade the GPU at some point, as a 10400 will likely be GPU-bound with your current one. But it would get you started in a newer platform more suitable for ugprades. The nice thing about most newer boards for LGA1200 / LGA1700 / AM4 all support DDR4 RAM, as well as M.2 NVMEs, which add a fair amount of zip to most any configuration. Not that 4th gen is bad, but 10th gen is definitely better than 4th gen.
But to really do this right with suitable RAM, cooler and decent board, even with the budget 10400, you're looking at $481 USD, or 450 euro.
Budget (including currency): to 150€
Country: Latvia
Games, programs or workloads that it will be used for: CSGO, Apex, some Sony Vegas work
CPU - Intel I5 4690
GPU - GTX 750 TI 2GB
MB - MSI H81M P33
RAM - HyperX 16GB 1600MHz (2x8)
PSU - Corsair CX550F 550W
STORAGE - 120GB SSD for OS / 1 TB x 3 HDD for games etc
Hello. I have a pc that, well isnt the best, but can do what I want to a limit. Ive been looking for ways to upgrade -mainly in the CPU path. I have my eye out on an i5 10400F (which of course means mobo and ram upgrade) for 100eur. Is it worth while the upgrade to get more fps or should I look further for a more meaningful upgrade? Or should I look in to a different upgrade path? Thank you in advance for the answers!
https://linustechtips.com/topic/1435903-should-i-upgrade/
How much is an i3 1200/1200F? If memory serves it's a bit faster than the 10400. Coworker has one, monster of a tiny chip. And it'd get you onto a platform with PCIe 5.0/4.0 support (you can get good B660 boards for pretty cheap, at least here in the US).
If that isn't an option, the 10400F will still be a night and day upgrade over the old i5 in any CPU tasks, especially in video editing. In games, even though the 750 Ti would be what holds you back the most, you'll probably still see an fps bump (especially in CSGO) and definitely better 1% and .1% lows/frametimes which should make games feel much smoother.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429202
150 Euro is $160 USD. With that budget, I don't see doing what you'd like. There are better processors on your current platform, but you really should consider changing platforms as well. Unfortunately, there don't seem to be any better CPUs on your platform, nor a board and CPU combo that would be any better, for the budget you state.
Edited by An0maly_76
Revised
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429203
Ok! If its a night and day difference, im sure Ill check in further for mobos and ram!
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429238
On the 1150 socket platform, only a I7 4770 is an option worth thinking about, but its so overpriced here, its sad. I rather change platform and upgrade to the i5 10400F.
Lets increase the budget to 200eur maybe, what can I get, that would be better?
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429240
With a 750ti the only thing you'll see a benefit in is vegas.  You'd probably need a new GPU too for games to run any faster.
For 200 Euros you could get a 1070 if you snipe on in an eBay auction, and your games would go way faster.  For GPU, motherboard, RAM, and CPU, you're SOL.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429285
Country: Latvia
CPU - Intel I5 4690
MB - MSI H81M P33
12100f's build
you have low money
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429315
Revised, more info
https://linustechtips.com/topic/1435903-should-i-upgrade/#findComment-15429336
