Posted May 21, 2022 Parts are all "new" as in i just unwrapped them. I have been collecting smaller bits like the case and lights and fans for a few years. With the price drop i got most of my major parts like cpu, mother board, and gpu. Cpu: 5900x Gpu: xfx 6600xt Mb: gigabyte b550i aorus pro ax, itx Psu: coolermast v850 Case: darkflash dlh21 My bios: f13, but tried f14 and f15 with same results. Ram: corsair vengense pro 8gx2 Corsair led strip Noctua fans to replace case fans for noise Corsair h60 aio cpu cooler Ssd: samsung 980 250g, samsung 970 pro 1t, and Seagate barracuda 4t Ok. Did the bios flash and I get fan spin. However, I cannot get anything else. After flash, the fans kick on. Once they stop completely, I try to boot using power button from case(all plugged in correctly) and no go. Flip off power and clear cmos. Try to boot again. Nothing. Rip out the case connectors and try to short the pins with same result. I know I get power because usb devices light up under 5v. So I have power. Everything I flash, same results. I can get led strips and fans to power up, but nothing else. After 10 minutes, those also turn back off and I have no way to power them up again except to do another bios flash. Running minimal things on the board. Next thing is that it must be a bad cpu, right? Even though it is brand new? Just needing to bounce stuff of someone. Thanks for any insight. I have 5 days left to return the cpu. I fear i may have too.... Link to comment https://linustechtips.com/topic/1432441-power-but-no-boot/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 26, 2022 Author On 5/21/2022 at 7:14 AM, Hurtstiff said: Parts are all "new" as in i just unwrapped them. I have been collecting smaller bits like the case and lights and fans for a few years. With the price drop i got most of my major parts like cpu, mother board, and gpu. Cpu: 5900x Gpu: xfx 6600xt Mb: gigabyte b550i aorus pro ax, itx Psu: coolermast v850 Case: darkflash dlh21 My bios: f13, but tried f14 and f15 with same results. Ram: corsair vengense pro 8gx2 Corsair led strip Noctua fans to replace case fans for noise Corsair h60 aio cpu cooler Ssd: samsung 980 250g, samsung 970 pro 1t, and Seagate barracuda 4t Ok. Did the bios flash and I get fan spin. However, I cannot get anything else. After flash, the fans kick on. Once they stop completely, I try to boot using power button from case(all plugged in correctly) and no go. Flip off power and clear cmos. Try to boot again. Nothing. Rip out the case connectors and try to short the pins with same result. I know I get power because usb devices light up under 5v. So I have power. Everything I flash, same results. I can get led strips and fans to power up, but nothing else. After 10 minutes, those also turn back off and I have no way to power them up again except to do another bios flash. Running minimal things on the board. Next thing is that it must be a bad cpu, right? Even though it is brand new? Just needing to bounce stuff of someone. Thanks for any insight. I have 5 days left to return the cpu. I fear i may have too.... Decided to swap motherboards and buy a new one. Same issues, so it must be a dead CPU. Really bums me that when I finally get my hands on a new CPU it is DOA.... sigh..... Link to comment https://linustechtips.com/topic/1432441-power-but-no-boot/#findComment-15411911 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2022 Author On 5/26/2022 at 3:17 PM, Hurtstiff said: Decided to swap motherboards and buy a new one. Same issues, so it must be a dead CPU. Really bums me that when I finally get my hands on a new CPU it is DOA.... sigh..... Do now I have swapped the power supply, motherboard, AND CPU. I now have a 5600x and it has the same behavior. Pulled everything off the motherboard except a fan. Flashed the qflash. Plugged in cpu, m.2 ssd, 1 stick of ram, and a 6600xt gpu. Try jumping to power pin, annnnnnnnnnnd nothing. Anyone have any suggestions? I'm using a 16g usb stick, so im gonna try a smaller one if I can find one. Really need some help with this. Link to comment https://linustechtips.com/topic/1432441-power-but-no-boot/#findComment-15434299 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
