Power button LED cable mod question
Solved by Noxitb,
1 hour ago, AtomicGaming said:So, I bought 2 power buttons, one for the main power button, and one used as a reset button. I'm looking at trying to mod the power LED +/- on the power button thats being used as a reset button. When the main power button gets powered on, both power button LEDs come on. Same on the off state but the LEDs are off. My question is should I put a resistor in case of signal interference, or should I not worry about it?
i would put a resistor because there is a chance it could short or have signal interference
