21 minutes ago, carpet.- said:
what are your temps looking like? gpu might be thermal throttling hard
also if you have msi afterburner, the card might be power limited?
check that too
hope this helps! 🙂
Temps are great at least i think so, they are 50-60. And about msi afterburner i dont have it, i have some asus gpu tweak or something
https://linustechtips.com/topic/1421865-tuf-rtx-3080-problem/#findComment-15331203
